Jeti JES 110 Programing Help me
I just got a second hand EP Sig Rascal with a Speed 400 motor and a Jeti JES 110 speed control. There was no receiver in it and when I installed mine the throttle and rudder were reversed. I got them right with my transmitter and all seems OK, but I would like to know how to program the JES 110. From what I have read speed controllers go into programing mode when you energize them and the throttle is at full. Well I had the throttle full back when I first turned it on, but since it was reversed the speed control was beeping and I think it thought I was giving full throttle. I have read that the brake can be set on or off, and when it is off the control will beep when first initialized, it doesn't beep for me. And I would suspect that the timing could be altered. It's too windy for me to get out and try it, but I would like to know how to set it up correctly since I might have changed it by accident.
Can anyone out there point me to an on-line manual or give me set-up instructions? I have googled and webcrawlered and can't find anything.
Thanks, rod.
Thanks, rod.
RE: Jeti JES 110 Programing Help me
Rod, try this site
http://www.jetimodel.cz/eng/hlavnien.htm
They have some zip files that you can look at which may help
Ed
Ed
Thanks for the address, I looked and they have everything but the 110. I sent a request to them from the contact icon so maybe they will respond. Thanks again.
rod
rod
ORIGINAL: rod2_hi
rod
rod
Good Luck
Ed
