Gws gearbox gear change
My Feedback: (10)
WA
When changing gearing on the gws gearbox do you have to change the pinion gear? I changed the big gear from a b to a d and it seems to work fine. I am running a himax 2015-4100 in a foamy 540.
TN
RE: Gws gearbox gear change
Pinions and spurs are matched so that the distance between motor shaft and drive shaft remains the same. If you change one but not the other you will have a mismatch (perhaps small in changing from B to D but a mismatch nonetheless). The bigger diameter the spur gear is, the smaller diameter the pinion HAS to be and vice versa.
If that's a GWS 300 gearbox: Your B ratio was 62/14 = 4.43. D ratio should be 66/10 = 6.60, but you have made it 66/14 = 4.71. That (bigger than it should be) 14T pinion will be meshing deeper, and perhaps binding in the (also bigger) 66T spur - and, of course, you haven't changed your ratio as much as you really wanted to!
Cheers, Phil
Cheers, Phil
CA
Besides the fact taht you no longer have a standard gear ratio of D also. Since you only have HALF of the D setup it's not a true gearing.
Also agree'd with matt. Change both Spur and Pinion.
FL
I believe that Bishop's power products sells an adaptor plate that would allow you to just change the spur gear. The gearing still won't be the same as the stock GWS because you're not changing the pinon.
John
John
My Feedback: (10)
WA
That is what I have a b p p adapter plate and a himax brushless. the gear change just didnt seem right and no matter how I ajust the mesh it stills seems to bind a little on start up, so I ordered a whole set up with the D pinion.
