Setup Question
Setup Question
Hi every one, I have the following question, I own a Lil´Rascal with 180 size motor with gear drive, a 350mAh Ni-MH (7-cell 2/3 AAA size) and Airtronics Flight Pack 5-Channel Micro 20 Amp ESC, the manual call´s for a 4 to 10 Amp ESC, and the problem that I have is that when I connect everything the throtlle works fine but when I move the ruder or elevator the throtlle is activated, the radio is a VG400 and has no programing and mixing capabilities.
The Airtronics Flight Pack 5-Channel Micro ESC includes :
One 92515Z 5 Channel FM Single Conversion "Z" Receiver with Crystal
Two Super Micro 9gram 94091Z Servos
One Mini Amp ES-20 Electronic Speed Controller
One Set of Servo Accessories for servos
RE: Setup Question
I will check about the servos, I do not think I connected backwards, but what I´m very sure I did was to connect the receivers battery and the throttle cable from the ESC that has power at the same time so maybe I over powered the rx, Is any thing I can do?
Thanks In advance
Thanks In advance
