Speed 400, what Himax replacement
My Feedback: (9)
IN
What is the preferred Himax motor to replace a speed 400 direct drive. It's in a Zagi style flying wing. I want faster top end and generally better performance. I will likely be using 3s2p Kakam 1500's but still have 9.6v packs also.
Thanks,,,Matt
Thanks,,,Matt
CA
RE: Speed 400, what Himax replacement
I don't know much about Himax brushless motors, but I run a Astro 020 5 turn in my wing and its an awesome setup. You should check it out, go to www.zagi.com and call up zagi bout the motor if you'd want to learn more bout it.
-Steve
-Steve
