Speed 400's enough?
GA
Speed 400's enough?
Guys, I have a twin electric floatplane that weighs 29.75 oz. empty, and it has two Speed 400 Graupner 7.2v motors which weigh 5 oz., upping the airframe weight to 34.75 oz. The plane has 478 sq. in. of wing area. The prop shafts are 3.75" from the fuselage, giving me a 7.5" dia. max. prop. I don't think these motors are enough, but I would like to hear your ideas. I was thinking of these motors:
http://www.hobby-lobby.com/speed400.htm
The FK5202 long can at the bottom of the page, using a 6X4. Any thoughts?
Thanks, guys!
Thanks, guys!
My Feedback: (32)
AZ
RE: Speed 400's enough?
Without running the numbers through, just seems like it would be kinda heavy(kinda really heavy for direct drive). The 6v 400 might be better. How about brushless...? (yeah, I know, $$$)
My Feedback: (21)
Whatever you do, you'll want the maximum that the motors can handle. That's around 12 Amps at full throttle.
He's right, though. If you want powerful performance, 16oz-18oz per motor, running the motor at full capacity, is about it. You're looking at aroud 25oz per motor when all is said and done.
What a 480 motor will gain you is a moderate increase on power handling capacity, allowing you to run 15 Amps instead of 12. You can also run 10 cells instead of the 8 on a 6V Speed 400.
A 7.2V Speed 400 can also handle 10 NiMH cells, or a 3S LiPoly, but is still limited to 12 Amps.
GA
Thanks, Matt. 15 amps sounds much better. The 480's will be my next choice, for sure. Is the long-can 400 the same as a 480? I notice it will handle 12 volts.
Is this the lipoly you mentioned?
http://www.hobby-lobby.com/kokam.htm
FM15003?
Can that pack discharge at 25-30 amps?
FM15003?
My Feedback: (21)
Long can 400 is generally called a 480, correct.
That LiPoly pack is rated 8C, for a maximum discharge of 12 Amps. You'd want at least three in parallel, using the kokam parallel module also sold by Hobby Lobby. They'll cost more, but still be lighter than a 10-cell 3300mAh NiMH.
Another option is the Kokam 2100 (20C) pack. 2100mAh at 20C is 42 Amps.
GA
Thanks, Matt. I noticed Tower recommends a speed control made specifically for Lipoly's. Will a standard speed control allow the Lipoly's to discharge too low?
GA
UPDATE: I made an 8-cell pack with the 1250 SCR's (?) and wired the motors in parallell. I'm getting 9 volts at the motor, and I'm reading 12 amps using a 1.7:1 gearbox and APC 7X4 electric props. This is my first test with twin motors. Am I drawing 12 amps per motor, or is this for both motors? I have a current/volt meter I made, and I plugged it in between the battery and motors connection.
How do you determine the safe discharge rate of a nicad or nimh if it isn't published? I bought a new 24v cordless drill battery in order to rob these cells, but I don't know the safe discharge rate.
