Help with MP Jet Hook up
I just purchased and MP Jett motor with the MP jett speed control. The motor has three points on which to solder the wires coming from the speed controler, however the directions give no indication as to which wire goes to which position on the motor. This is my first electric, so I was very suprised to find no instructions on were to put the wires. I have done wiring in my home and ther is a hot leg a common and a ground and to mix them up is a bad thing. Please help.
RE: Help with MP Jet Hook up
It really doesn't matter which wire goes where. Once they are hooked up if it runs backward you swap two of the wires over and it will be running in the right direction. No damages will occur from running it backward.
