Align motors
Align motors
Does any one have any experiance with the Align BL motors??
http://www.align.com.tw/shop/product...roducts_id=756
specificaly the SF400 series, are any of them suited to direct drive on say a 3DF plane?
I was thinking of the 1100Kv one for direct drive or the 2800Kv one for say a 6-1 box
My Feedback: (21)
RE: Align motors
The link didn't come through; the "..." in the middle is translated as a "...". Align rings a bell, but I can't think of where I heard the name before. What's nice about electric motors is that as long as they're not total junk, they can be convinced to perform.
Going by what I typically see, a 2800Kv motor would be more suited to a 4:1 or even a 3:1 ratio, unless you're thinking about spinning an extremely large prop for mostly hovering maneuvers. The 6:1 gear ratios are better suited for hotter motors in the 4100, 4200 Kv range.
RE: Align motors
Just updated the link.
So Matt what your saying is typicaly say an 1100kv or 1500kv is more suited to direct drive aplications.
RE: Align motors
My friend is using an Align 400l 2500 kv on a Stryker wing. He is using a 7x6 direct drive prop, it draws about 29 amps.
The Stryker with the Align is comparable to a Mega 16/15/4 with a 6 x 4 prop.
Another of my flying buddies is putting together a Stryker with the Align 400s 2800 kv motor.
If you try these motors get the heatsink!
RE: Align motors
the "F" motors have a cooling fan as part of the rotor so may be this will help, but for the extra few bucks i'll get a heat sink as well.
