AXI 28/26/10 0UESTION
HELLO I have a axi 28 26 10 motor and a C C 45 amp speed control. When I use a 12/8 prop with a 3s2p 4000 mah batt it cuts off at about 35 amps about 3/4 to 7/8 throttle. But when I use a 10 cell 1700 nimh it runs fine up to full throttle about 42-44 amps. Can anyone explain that? I have set my controler to the last step before turning the current limitor off. I guess it would be o.k. to do this as long as I check it with a watt meter? If you can shead some light on this it would be a great help Thanks
