mega 16/15/3 dual setup?
PA
what esc(s) and lipo(s) will be required to get 2 megas (16/15/3 or equiv) up and running? one or 2 esc's? looking for 18k to 20k rpm and decent flight time.
using for dual EDF application.
RE: mega 16/15/3 dual setup?
sounds like you will need at least a pack that can handle 30 amps that would mean that you would need at least two 3s or 2s packs in paralell. the higher the mah the better as far as the speed control you would need one for each motor. Although I have heard of people using one for both. depending on props and current you can figure the amp draw. with d/f a watt-meter is the way to go.
