AXI 2208-20 problem
CA
I,ve run this motor about 6 times in a little thunder tiger glider, then out of the blue it starts giving me fits I throttle up and about half way it sounds like a vibration and it shuts down only to react to starting throttle over again shutting down at 1/4 throttle.It will run fine without the folding prop which is in good shape ?
GA
usually if a motor cuts out it is because the battery can't supply the necessary power..
what prop, esc and most importantly what battery are you using?
