is this esc ok for my motor and lipo?
hallo all,
i just bought an axi 2808/24 , 3s lipo , 10/7 prop and jeti 18amp.
will i need to replace my esc ?
thanks
thanks
AZ
ORIGINAL: oran
hallo all,
thanks
hallo all,
thanks
Please keep in mind that these numbers are a referance only and if you have access to a watt meter that is the way to go.
Sorry to say this INeedHelp, but both datasheets from AXI and practical testing shows me other numbers than you get from Motorcalc... I have long time ago stopped to use Motorcalc since the numbers it gives often are wrong in a lot of the tests I have done myself and read. I only thrust ampere-meters and wattmeters, and use both to double-check.
But the motor would work fine on 9x5, only remember not to run it static for more than a few seconds.
AZ
ORIGINAL: INeedHelp
I agree INeedHelp, Motorcalc works Ok several times, but sometimes the difference from practical tests are large. And of course Motorcalc depends on numbers from the producers, and slightly wrong numbers will cause wrong results. Nothing works perfect everytime, and something that makes these thing so interesting is just the ability we have to doublecheck and try to figure out why and how and so on
