HACKER B20 ??
WA
You need a programming "card" for some Jeti controllers. If you use a Castle Creations, you can either use the built-in programming, or use the PHX-Link via a USB port. Hacker controllers probably have the programming built in. It's all in the controller when it comes to programming.
You'll like the B20. Spools up instantly, and get the Maxxon gearbox that's pre-installed with it. Liquid smooth. Got a B20-22S in a Shockflyer, servos lock on me at full throttle [X(][X(][X(][X(], I recommend a 2 cell setup for a 3D plane, 3 cell for ripping the wings off! So you know, the elevator and wing are cocked 45 degrees off from one another at full power simply from the torque....
