Pinion Gear Help
I built an APEX DIY 400 brushless motor with 3mm shaft initially for direct drive application, however, I wanted this motor for a gear drive system. My problem now is, I need a pinion gear that will fit the 3mm shaft. It is difficult to look for this size over the websites I've checked.
Is there anyone who can suggest to me where to buy the Pinion Gear I need that will be mesh with a GWS spur and gear drives ? [:-][8D]
Any help and suggestions will be appreciated.
