Program ECS help
Program ECS help
I need help with a Thunderbird 9 speed control, brushless. The motor would not run at full throttle only 1/2 throttle so I though I would re program it. BIG MISTAKE. Now it will not enter the program mode and will not recognize the 3 Li-Pol cell. It only continally beeps what Castle calls "the first multi tone ring"
OK I am a newbie but need help.
Stan
Stan
CA
RE: Program ECS help
[8D]I have not heard of a thunderbird 9 speed control, but you did mention castle.
Is it one of theres ? What are you using for control? Computer radio, standard, three or four channel.
If it continualy beeps, the controler probably isn't even. getting a signal.
What current are you drawing, motor and prop combo? need more info!
It is a Castle Creations new item Thunderbird 9 brushless controller.
I am using a Futaba Skysport 4 channel radio
I really do not know what current is being drawn
Motor is a Himax brushless outrunner hc 2808-0980.
If I can not save this esc I will purchase another perhaps you can suggest.
I am just dying to get this plane up
Thank you for your support
woww, i was looking for the answer cause i am having the same problem but nobody want give me the secret....
That would have been so nice TO GET IT FROM YOU. THANKS
