***JETI Brushless controller programing question***
Does any know the programing sequence for a JETI ADVANCE 30-3P Brusless controller? This is the predicessor to the newer ADVANCE PLUS and is programed through your tranmitter using a series of beeps. All I could find on JETI's site was how to turn the brake on and off. I need to know the sequnces for changing the hard/soft timing and to set it for Li-po batteries (which may be an auto detect setting, I don't know). I am running a mega 16/15/4 can motor with a 2100mAh 3S Li-po pack so I think I need to set the controller for soft timing. Also, do I need to set the cut-off voltage? I would love to hear from anyone that could offer some advice or sugestions. Thanks, Bart
hello,
I have the 18 amp version...to set the timing mode....
disconect battery
push your throttle all the way up
connect battery and wait for beeps
Beep, Beep, Beep, Beep, ect. is timing mode one .....Beep Beep, Beep Beep, Beep beep, ect. is timing mode two. (outrunner mode)
once you hear it beeping once (consecutivley) close the throttle to set it in that mode......if you want it in mode two...close it while it is in the two beep sequence....that is it..it will beep once to let you know it is armed...and it is ready.
hope this helped...I would check from jeti's online instructions...I have found it before...through an internet search.
theharpman.
disconect battery
theharpman.
