Which Hacker?
GA
Curious which hacker you would recommend....
this is for a 26oz 3D plane.... (currently and Electrifly Sukhoi, but want it for use on others in this weight range)
Will be using a Phx-25 (a bit low on specs, but OK for now) and TP 2100mAh 3 cell packs.......
Trying to decide between the A30-16M or the A30-12M
http://www.hackerbrushless.com/motors_a30.shtml
Leaning towards the 16M... even though its wattage/kv is lower, it can spin a bigger prop...which would be better for 3D style flying.....
am I correct in my logic?
Exeter
Exeter
