Need help with Walkera 3200Kv motor
Does anyone know the screw size on the motor mounts of the Walkera 3200Kv motor? I don't have them and don't know what size they are. HELP!
JD
JD
ORIGINAL: wake wacker J
JD
JD
I have two of those motors one of them uses 2mm bolts/screw and the other one uses 2.5 mm bolts/screw.
Make sure that you do not get to long a bolt. If it is to long the end of the bolt will get pushed into the motor windings and can damage them.
Glen
Thanks a lot! I did find the right screw. It appears that the holes were so poorly tapped that it didn't seem like it fit. I forced a 2mm screw through the holes which fixed the threads and now I can get back to building.
JD.
JD.
