MPJet 28/7-35D Brushless Motor
NY
Just purchased this motor for my new Japanese Hayate warbird. Motor has 3 solder points. How do you know which wire, white, red, black, goes to which solder point? Thanks.
The White wire normally goes to the center solder point the red and black go to either side !
Which side depends on wether it will be pusher or puller ?
Solder the wires on then check for rotation if it is the wrong way change over the red and black wires only ?
have a look here : http://www.megamotorusa.com/Tech%20S.../PhoenixTS.htm
[8D]
[8D]
Connect them in any order, turn it on and see if it rotates the direction you want, if not swap any two (2) wires and you are in business. Don't worry it won't hurt anything (just watch out for your fingers).
NY
In addition, the esc came with a program card.This might as well be from another planet.What do I do with this?
