Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Brushless motors in DVD player??
Old 10-16-2005, 07:57 AM
pilott34
Default Brushless motors in DVD player??
Ive heard of guys using motors out of a CD ROM player in a foamie plane. Im looking to build my own foamie and I am starting to acquire the parts. Have an old broken DVD player that I am not using, will the motors from DVD player also work?? What size ESC would I need??
Mike
Old 10-16-2005, 10:37 PM
jdetray
jdetray's Avatar
Default RE: Brushless motors in DVD player??
If the DVD motor is a brushless motor with a multiple of 3 stator teeth, then it may be usable. The brushless controllers we use require a multiple of 3 teeth.
The current rating of the ESC depends on how many turns of wire you put on the motor. In most cases, the no-load current will probably be less than 2A. When you add a prop, you'll definitely want to have a wattmeter connected to monitor current consumption.
- Jeff
Old 10-17-2005, 10:42 AM
AgCat1982
AgCat1982's Avatar
Most of these guys rewind and re-magnet the cdrom/dvd motors. Otherwise, you won't get much out of them. There are entire websites on the subject.
If you want to try it, go here for a start..... [link=http://www.gobrushless.com/ccp51/cgi-bin/cp-app.cgi]GoBrushless.com[/link]
Good luck
Old 10-20-2005, 04:56 PM
ron_van_sommeren
ron_van_sommeren's Avatar
Do-it-yourself motor homepages, manuals, checks and tests in the first message of this motor builders tips and tricks thread. The checks and tests may save you from frying your controller. Thread is active, bookmark it for future refence and subscribe to it:
http://www.rcgroups.com/forums/showthread.php?t=240993
Vriendelijke groeten Ron
• diy motor building tips & tricks
• diy outrunner discussion group
• int. E fly-in & diy outrunner meet, June 25 2006, Nijmegen, the Netherlands
