Hacker A30-28s/ph35 stutter problem
CO
I just got a new Hacker A30-28s Ph 35 combo and am having some trouble getting it all set up. Right now the motor just stutters and no matter what I do will not spin in one direction. In the past I have just had to do some playing around with the 3 wires to get past this. I have now spend a long time swapping wires, and configureing thru the usb link with no luck.
I have upgraded to the latest firmware, adjusting timing advance, soft/hard start....nothing works. Still just studders.
I have noticed that I only get the audible beeps sometimes... Am I supposed to do somthing to the ESC to reset it each time I swap wires? I am out of ideas on how to get her working.
Any ideas?
Any ideas?
My Feedback: (13)
CA
RE: Hacker A30-28s/ph35 stutter problem
Check the charge on the battery. Go back to your controller setup and go through the steps again. You have great stuff, should be no problem. If you still have a problem, go direectly to the hacker people. I had the same problem that turned out to be programming with 1 wrong lead. They should make the leads a little easier to match, but who else gives you this already made up?
GA
Yep... check the battery... after that it is hard to say...assuming the ESC is programmed correctly....
sounds like timing though....
will the prop start if you give it a little push?
My Feedback: (9)
I've had this problem a couple of times with brushless motors. Just switch any two wires and it should run fine. If it's running the wrong direction, switch a different combination of two.
Walt
Walt
CO
I have tried all that has been suggested and still no joy...I resoldered the wires twice, and finally swapped out an ESC I already had, and the motor spun fine. I think the ESC needs to be replaced.
I have an extra PH 25...you think that would be alright to run with the Hacker A30-28s?? Says top amps is 25??
My Feedback: (24)
GA
I had a problem with a outrunner and CC 25 after I updated the softeware, Reloaded older software and then it worked fine after that.
Milton
Milton
