AXI 2208/34 bearing change?
QC, CANADA
Is it possible to change bearings on AXI 2208/34, I got one that started recently to make some bizare noise, it sound like a brushed motor with a gear.
The second one is making some erratic "clunk" nose like twice a second irregularly, would it be the timing advance that is not properly programmed in my CC Pheonix 10 , I set it to standard?
My Feedback: (45)
MI
RE: AXI 2208/34 bearing change?
Dany boy,
Sounds like the magnets have come loose ........... I think the older versions did that?? What size plane is the 2208-34 on?? How many oz.??
regards, zz
regards, zz
QC, CANADA
I found the problem, it is the C clip on the shaft that was touching my firewall and was kept from rotating which created this crazy noise.
Plus the CC Peonix 10 was set for strong motor startup which creates some clak clak noise sometimes when playing with trottle on and off rapidly and the clak noise amplifies thru the 3mm depron
Shocky 10 ounces...
Tkx anyway
Shocky 10 ounces...
Tkx anyway
