Hacker 20-22L mounting?
I need some help with the mounting of the Hacker 20-22L. I am not exactly sure how the motor and wood plate mount to the mounitng bracket.
RE: Hacker 20-22L mounting?
Tell us what plane you are putting this on. I have one on a foamtana that mounts directly to the plywood on the foamtana. But I am assuming you are mounting this as a rear mount. Therefore you may or may not need to use the plywood provided. Again, depending on what is supplied in the model.
