CC25 and Ultrafly A/30/24 Problems ??
Hi,
I have had some terrible problems with my Castle Creations Phoenix 25 ESC and the Ultrafly A/20/24 in the direct drive configuration. At around 1/2 to 2/3 throttle I get a terrible reasonance from the motor and it tries to tear the test stand apart. I have tried props from 4.5" up to 6"x4". I have used two different prop balancers. I have used 2 cell, 3 cell batteries and a laboratory power supply. I have tried 3 different samples of the same motor due to the great support of my supplier. I have changed timing on esc.
Then I got a MEGA 16/15/4 and it runs like a dream. I would love to know what was going on with the Ultrafly and if I have a problem with the esc.
Thanks in advance for any suggestions,
Jeremy
Jeremy
MD
RE: CC25 and Ultrafly A/30/24 Problems ??
Sounds like a motor problem to me. Have you checked to make sure the shaft is true? I have a CC25 and A/30/29 that I have been running, and it's doing fine (gear drive though).
