What do you think of this Brushless Motor?
Hello All, I would like to put this motor in my new GWS P-51 and Ace Simple Corsair. I just got it from Polks Hobbies. I'm new to brushless, and need pro input. Thanks, Mike.
BRUSHLESS OUT RUNNER MTR.W/THREADED SHFT
BRUSHLESS OUTRUNNER MOTOR W/THREADED SHAFT and MOUNT dimensions: 30.6 x 62 mm Kv[Rpm/V 1750 Weight 46g Operating range 7.2-12.6V Operating current 1.8-13 A Peak current 15sec @15A
WA
RE: What do you think of this Brushless Motor?
If you could post the wingspan, weight, and wing loading of the plane, it would help. Also, what kind of performance do you want?
Wing Span on both planes are 32", weight 16 to 18 oz. I'm not sure of wing loading and i'm just looking for "sport" flying. Thanks, Mike.
WA
That motor should be enough. You will want a smaller prop though, because the kv is higher than most outrunners. Use a 3 cell lipo, and aim for 12 or so amps.
