[ELE EC28P]-A motor deserves to recommend.
Test results:
ELE EC28P-S
length: 9*27*47mm
KV:1540
weight:29g
diameter:28mm
shaft diameter:3.175mm
prop ------voltage -------current --------Thrust force ------power ------Efficiency
7035--------7.4-------------3.6 ----------------182-----------26.64----------6.83----------
-------------11.4 -----------6.5 -----------------336 ----------74.1------------ 4.53--------
9050 -------7.4 ------------7.7 -----------------281 -----------56.98 -----------4.93 ---------
-------------11.4 -----------10.3 ---------------400 ------------117.42---------- 3.41 ---------
1047 -------7.4-------------0---------------------0----------------0-----------------0-------------0
-------------11.4------------0---------------------0----------------0-----------------0-------------0
ELE EC28P-M
length:13*29*51.5mm
weight:38g
KV:1650
diameter:28mm
prop ---------voltage --------current -------Thrust force------- power ------Efficiency -------
7035 ----------7.4 -------------7.8 --------------314 --------------57.72 ---------5.44 -----------
----------------11.4 ------------10.1 -------------460 --------------115.14 --------4 ---------------
8040 ----------7.4-------------- 12.6 -------------471 --------------93.24 ---------5.05------------
----------------11.4 -------------13 ----------------586 --------------148.2 ---------3.95 -----------
ELE EC28P-L
length:16.4*33.5*55.4mm
weight:49g
KV:1140
diameter:28mm
Prop ---------Voltage-------- Current --------Thrust force ---------Power -----------------Efficiency ---------------Remark
7035 ---------7.4 --------------2.9 ---------------132 ------------------21.46 ----------------6.15 ---------
---------------11.4 -------------5.6 ---------------333 ------------------63.84 ----------------5.22 ---------
8040---------- 7.4 -------------5.2 ---------------273 ------------------38.48 -----------------7.09 ---------
----------------11.4 -------------9.6 --------------530 ------------------109.44 ----------------4.84 -----------
9050 ----------7.4 --------------8.4 ---------------400 ------------------62.16 -----------------6.44 ----------
----------------11.4 -------------15.8 --------------676 -------------------180.12 ---------------3.75 ---------- ---recommend
1047 ----------7.4 --------------11.9 -------------504 ---------------------88.06 ---------------5.72 --------------recommend
----------------11.4 --------------18.8 ------------795 -----------------------214.32 -------------3.71 ------------
ELE EC28P-S
length: 9*27*47mm
KV:1540
weight:29g
diameter:28mm
ELE EC28P-M
length:13*29*51.5mm
weight:38g
KV:1650
diameter:28mm
ELE EC28P-L
weight:49g
KV:1140
diameter:28mm
RE: [ELE EC28P]-A motor deserves to recommend.
This outrunner motor is really deserves your attention.they are tested and rewound by many people.But I think the most attractive thing is the low price.$10.99---$11.99---$12.99
