Brushless Motor Dead ??? It just Beeps continuously
My Feedback: (92)
I have new ducted fan plane with an GP Ammo Brushless and GP Silver series ESC and when everything is hooked up the motor will not arm. It just constantly beeps and will not turn over. I have reversed the radio throttle, no change. I have switched batteries, no change. I have even swapped ESC controllers with another GP silver series brushless ESC and still no change. The ESC is plugged into the correct spot on the reciver. I don't know what the deal is.
Could the motor be bad?? I don't know how it could be. Its brand new as is everything else I have.
My Feedback: (20)
LA
RE: Brushless Motor Dead ??? It just Beeps continuously
Make sure the speed controller i plugged into the throttle on the receiver not the Bat.
If that doesn't work try changing you radio over to Helicopter mode throttle it up then change back too plane mode.
I had the same Problem and found out threw trial and error finally got it up and going.
Take the motor out to run it so it runs revers you can change 2 of the wire only between the speed controller and the motor so it will run the right way.
Good luck Jim Wells
Good luck Jim Wells
My Feedback: (21)
The constant beeping indicates that the ESC is not recognizing that the throttle is in the OFF position. Check that your throttle trim is centered. Check to make sure any EPA and/or ATV settings for the throttle are set to 100%. On a Futaba transmitter, make sure the throttle reverse is set to "reverse."
I also had such a problem with the 60A towerpro esc's. If all else fails try hooking up a seperate battery reciever pack. I found out that infact the esc's I was using didnt even have a working BEC (even though it was advertised). However only try this if all else fails. Make sure to have the trottle full LOW before power is applied to the esc, and the transmitter should be turned on before the reciever. All the other tips sound good too. Good luck! (I hate this fiddly things!)
