E-Flite Park 25 Motor shaft replacement
Hi,
does anyone out there (maybe eflight technical rep?) know where this round clip must be put on the shaft? I've no trouble changing all the parts but I'm puzzled about where this clip must be put.
My Feedback: (21)
The clip usually goes on the shaft end that protrudes through the base of the motor that's attached to the motor mount. It's designed to keep the shaft from pulling out of the motor when the prop is connected to the spinning end. There should be a groove in the shaft.
Thanks Matt,
this is where I decided to put it, it didn't make any sense to put it anywhere else on the shaft.
Eflight: a diagram would help? About some instructions with the replacement shaft?
