Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Brushless setup for Great Planes Yak 55
Old 10-23-2006, 09:15 PM
EzySetup
Default Brushless setup for Great Planes Yak 55
I have a [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKVY7&P=ML]Great Planes Yak 55 3D FlightFlex EP ARF 34.5"[/link] and would like to make it brushless (once the original brushed setup wears out).
What would be some good motor/esc/battery combinations that would perform at least equally as well as the stock setup (shown below)?
Thanks in advance,
Andrew
Current Stock Setup:[ul][*] Motor: 370 size equipped with ball bearings[*] 5:1 gearbox (50 tooth spur and 10 tooth pinion)[*] ElectriFly C-35 Mini Brushed ESC w/BEC[*] LiPo 11.1V 1500mAh 3S 8C[/ul]
Old 10-25-2006, 04:33 PM
Dr Kiwi
Default RE: Brushless setup for Great Planes Yak 55
Even thrashing your Speed 300 on 3s Lipo you would barely have got 15oz thrust.
Try this - you'll love it! Note the motor weight - your 300 with gearbox etc is at least 60g.
MicroDAN 2505/3D (32g): http://e-foamies.com/store/catalog/p...&products_id=1
9x5 GWS HD prop, Castle Creations Phoenix 10 ESC
10.6v, 9.20A, 97W, 7650rpm, 36.2mph, 582g, 20.49oz, 6.00g/W
You could even go to a 10x6 GWS HD and not exceed the motors specs.
Old 10-25-2006, 04:40 PM
EzySetup
This is great. It is exactly the kind of guidance I was looking to receive.
Thank you!
Andrew
Old 11-07-2006, 08:13 PM
PilotLight
PilotLight's Avatar
I've got a Great Planes Yak 55 EP 3D. Its the stryofoam model. Once the brushed system was wornout, I decided to upgrade to brushless. The motor of choice was a Welgard motor from BP hobbies. Its only $21 and puts out 21 oz of thrust with an 8x4 prop.
Here's the link:
http://www.bphobbies.com/view.asp?id...84&pid=W625875
I got longer flight times, cooler running batteries, and more power to get out of trouble. Really has improved my flying with this model.
Old 11-30-2006, 02:29 PM
dfalcon
My Feedback: (76)
Check these out:
http://cgi.ebay.com/800-rpm-v-Outrun...QQcmdZViewItem
Their prices are rising slowly but steadily (I paid something like $31 shipped for mine), but they are still a great value. It's a little heavier than most people might be using for this plane (57grams) but my Yak came out a little heavy anyway. My Yak's AUW is 18 oz and I'm getting 31 oz of thrust out of this motor with a 11x4.7 prop (31oz thrust, 14 amps, about 140W/lb). Using TP 1320's I get about 8 minutes of aggressive flying. I tried propping up to get the full 180 to 190 watts the motor is capable of, but the motor and the battery just didn't get enough airflow to keep cool.
I love these motors. I also bought the next size up (search ebay for BL2810) from the same vendor for $33 shipped (it's approximate size is between and E-Flite Park 480 and Power 10) to put on a Seagull models Extra 300 EP. It hasn't flown yet but I'm expecting great things. I'm also thinking about buying the larger yet BL2826 motor to put on a .40 sized plane.
Old 11-07-2008, 02:44 PM
RickyD77
I have an axi 2208/34 is this a good choice for this plane???
Old 11-07-2008, 05:29 PM
Dr Kiwi
A 45g Axi 2208/34 will be fine:
8x4 GWS HD: 10.7v, 7.80A, 83W, 9780rpm, 37.0mph, 522g, 18.38oz, 6.29g/W
You might well be able to push it a bit further, since your necessarily small pack won't deliver as much as 10.6v under load.:
9x5 GWS HD: 10.6v, 11.70A, 124W, 8310rpm, 39.3mph, 717g, 25.25oz, 5.78g/W
Old 11-07-2008, 06:48 PM
RickyD77
a big thanks!!!
