motor wire lenght
NC
I beleive that you can make an extension cable that will do the job.....Hope this helps.........
......You will need to have the wright connectors for this............[8D]
V2,
Which wires are you planning to lengthen, and by how much?
Most ESC manufactures recommend not lengthening the battery input leads, but rather it is better to add to the length of leads between motor and ESC.
Pete
Pete
