2 EFlight 400s on 1 phinix 60?
CA
Ok has anyone run 2 motors on 1 speed control? here is my question I am hooking up two EFlight 400s 4200KV inrunners on a phenix 60 on two ducted fans and its not working right is there a certin way to do this I have the motors on a Y set up to the speed control. I am also running 2 3 cell 2100 lipos also on a Y to the speed control basically its still 11.1v but still should push more amps I think any help on this would be great thanx all
Rick
My Feedback: (21)
Unfortunately, you've run into the problem with trying to run two sensorless brushless motors from one ESC. Sometimes it works, most of the time it doesn't. The problem is that the ESC depends on pulses received back from the motor to determine when to send the next pulse. With two motors, it's receiving mixed signals.
The only reliable solution is two ESCs for two motors.
