Hacker A20 / Phoenix 25 / Thunderbird 11.1v 2100 maH?
PA
Hello.
I am new to brushless motors and lipo batts. I bought a friend's plane as an RTF and I am concerned that the lipo battery is too much for my motor/esc. Here is my set up:
Hacker A20 20L
Phoenix 25 amp ESC
Thunderbird 3-cell 11.1v 2100 maH
Gear is all used in a Copperhead Extra Stiffy:
http://www.copperheadaviation.com/co...p?idProduct=69
My next question is, without a computer usb cable how do I program the ESC not to drain my lipo too much?
Jeremy
Hacker A20 20L
Phoenix 25 amp ESC
Jeremy
The motor should be fine with that battery, it is spec'd for a 3 cell LiPo 1200mah-2100mah, so you are within the range. The ESC should also be fine with that battery. You need to get the instructions from the person you bought it from or try to download them online to program it for the LiPo low voltage cutoff. I assume the battery is a Thunder Power, not a Thunderbird. The battery is my only concern, a 2100mah pack may be a little heavy for that plane. They seem to recommend a 1500mah pack. Which would be around 2oz lighter. As long as it flies ok and the Center of Gravity is not off with the 2100mah battery, it should be fine.
Here is the link for the manual, you will want to set the voltage cutoff at 9volts. http://www.castlecreations.com/suppo...er%20Guide.pdf
PA
Thank you!
Dang typo . . . ThunderPower not ThunderBird.
Spoke with previous owner/pilot about weight of batt, but he says that the discharge counters the weight.
TN
I beg to differ - a Hacker A20-20L with 3s and a 10x4.7 or 11x4.7 prop - waaay too much for the motor (the battery pack will be fine!)!
Even with a 9x5 GWS HD that motor on 3s draws more than its rated 15A continuous. With a 10x4.7,or heaven forbid an 11x4.7, it is going to be drawing well over 20A. [burst max for the motor is 19A]. Heck, with an 11x4.7 it draws 15.30A at only 7.1v - probably 25A or more on 3s!
PA
Dr. Kiwi:
Previous owber ran Hacker A20-20L with 3s and a 11x4.7 prop.
Cooperhead aviation recommends that set up (with a 1500 mAH lipo).
www.copperheadavaition.com for their Extra Stiffy.
I am new to brushless and li-po . . . Are you saying that my motor will fry?
Jeremy
Jeremy
ORIGINAL: Dr Kiwi
ORIGINAL: JeremySutton
Dr. Kiwi:
Jeremy
Dr. Kiwi:
Jeremy
PA
Thank you Fliprob17. I have a lot to learn still.
No black smoke stains or smell
or anything to tell me the motor isn't in mint condition. Hope to get a li-po charger for Christmas and then I will know all I need to know
The guy I bought it from is an honest and good guy.
He flew the 11x4.7 slow flyer prop for 3-D flight. Manufacturer recommends: APC 10X4.7 / 11x4.7 slow flyer prop.
I just check in with the previous owner again -- he did fly with the exact same set up he sold me. He had the 1500 maH battery, but sold me the 2100 maH for a good price and to give me longer flights.
Jeremy
www.quietflyer.blogspot.com
Jeremy
