axi motr turns wrong way???
i got the axi 2217/16 along with jeti 18 but when i throttle up it turns the wrong way.. i connected the wires with all the right colors but the prop becomes more of an pusher. any help will be appreciated.. thanks..
Don't pay any attention to the wire colors between the motor and ESC. The motor-ESC wires colors don't mean a thing with brushless motors. Just do as Mr Tee says!
- Jeff
- Jeff
Hi Playerpete,
In addition to Mr Tee and Jeffs fix, also some ESCs (castle creations for one ) have the option to reverse direction in the setup, real nice if you already did a nice neat solder job and it's all heat shrinked up
And of course never, ever even think about reversing the input polarity to the ESC[X(], unless you want to send smoke signals
Best of luck,
Pete
Best of luck,
Pete
ORIGINAL: powerlines
Yup!! And once the smoke gets out you can throw the thing in the GARBAGE!!
LATER
LATER
Pete
