Brushed Motors: What does the 480 mean?
What does the 480 (or 380 or 540 or 600) mean? Is it referring to rpm or Watts or what?
What is the equivalent of a 480 in brushless motor?
Xactibu
Xactibu
MO
RE: Brushed Motors: What does the 480 mean?
For a brushelss motor to match a 480 brushed motor, youd probably be looking for something in the 110-120 watt range.
Just a little clarification. They are not 480 mm long, etc..... drop the zero on any of those and that is how long the motor can is, so 48mm, etc......
AR
would like to know good brusless combination for nit-ro ultimate plane with 33 in wingspan and 25-30 oz weight. it recomends 400 size engine but need to know what bec will carry 4 severos and 1300 to 1700 3c lipolly battery the 4 servos are most of the problem recomended prop is 9.9-9.6 thanks for any help the stugg i now have will not move severos on 640 amp with 20c
http://www.e-fliterc.com/Products/De...rodID=EFLM1505
http://www.e-fliterc.com/Products/De...rodID=EFLA312B
I really like the E-Flite stuff. This ESC will do 4 micro servos without a problem. And the battery will be fine with this setup. You may want to jump to a 2100mah battery to get some longer flight times, closer to 15-20 minutes.
