Tower Pro bmc25a esc
BC, CANADA
Just purchased a couple of these esc (Tower Pro bmc25a) but they came without instructions. So far XHeli (the source) has not responded to my phonecall or email.
Does anyone have or know where I can get programming instructions for these. I have not seen anything specific for this esc. I'd like to get them flying...
PA
Tower Pro is know for not providing instructions for their ESCs and even then they are usually the wrong instructions. In addition, several versions of each ESC might be on the market with differing instructions. I went through this problem with the generation two 30 amp ESC. Please go to rcgroups.com in the power sources forum and look under a thread starting with "Coution" (Caution spelled wrong) and something about Tower Pro ESCs in the title. While this thread pertains to the 30 amp unit I bet the instructions may be the same. Either way, you'll find links to various manuals for the TP ESCs on that thread. Read the whole thread so you know what's up!
BC, CANADA
Thanks Critterhunter but I've been through that thread a couple of times and have not found anyting specific to this esc. If I get it wrong it'll probably fry something so I want to be sure I have the right instructions before I start messing around.
The model is Tower Pro BMC 25a. Here's the link... The esc was advertised as 30a but was delivered as 25a which is ok.
http://www.xheli.com/30aspco.html
It does not have a jumper, but I have also found a couple of versions of instructions that vary in the "Cell type" area with the same # of beeps for 2 or 3 cell lipo. If I get it wrong it'll likely fry something... Also how do I know what to set for "timing mode"?
There were also no instructions with the motor. By my count there seems to be 12 poles with fairly fine windings.
All I know about the motor is below. The motor delivered was also not the one pictured although I hope the specs are similar.
Thanks for your help
Regards
Ron
http://www.xheli.com/a2ha11rpmoub.html
Regards
Ron
