Help on How to connect a battery to a ESC then to receiver?
NV
I am putting together my first flat foamy electric plane myslef and I need a little help with the electronics. I HAD[&o] a Hacker A20 - 22 Motor with the X-20 ESC and I soldered all of the connections together and tried to put everything together when I connected my battery to the esc a spark shot out of my esc and into my hand giving me a few nice black burns..... Needles to say my ESC was shot. I had my battery checked and it is fine. I ordered a new ESC Castle Creations Phoenix 25. Ohhh I almost forgot to tell you the reason for the spark ( I soldered the ESC battery leads backwards making a positive to negative connection to the battery......OUCH that hurt.....
Anyway I would really appreciate some detailed info on how to run the esc to the receiver along with the servos? I guess my main question is when I connect the esc to the receiver do I put the esc plug into the battery slot on the receiver or do I put it into the throtle slot in the receiver? Do I need to add a power switch anywhere on the plane with the esc or does it just power up when I plug in the battery?
Any help you can give would be greatly appreciated , ESC's are expensive
ORIGINAL: dpsa98
NV
Thank you , Im going to try and put it together this weekend. I am waiting for this plane to come in the mail. It should be here in a day or two and I can fly it over the New Years weekend ....Darrol Cady Edge 540
Thanks Again
Thanks Again
