Need help,
I'm building a 2 stroke 25 size plane that I would like to convert to electric. I was just wondering if anyone could tell me what would be the best set up, or just a good set up for this plane.
TN
Depending upon your budget, the the AXI 2808 Brushless series would be my first choice, but you will need two brushless ESCs to control them. Two LiPo batteries rated at least 2100MAH at 11.1V 3S1P 15C will be needed. Hacker A20 series would probably work well.
This setup will be expensive. If it were mine I would go with a couple of 300watt outrunners from HK on ebay with ESCs to match. They have done well on my single motor planes.
For brushed setup probably a couple of 500 series motors would work.
I would recommend motors rated at least 20 Amps constant. I've never had a twin so I can only guess what may work. I do have 15 planes setup brushless and good success with them.
You may want to move over to the Glow to electric forum for better recommendations.
If you decide to go LiPo batteries be sure to use the correct charger!
Vultch
Vultch
Thanks. I'll look into those engines. I've seen the outrunners one ebay and they are realy cheap, but I've never heard of them before. Thanks for you help!
