gear box for Go-Brushless type cdrom motors
OR
Want to buy a gearbox that comes with pinion gears that will fit the shaft of a Go-brushless motor shaft (3mm). Failing that I wonder if drilling out a speed 400 gear box pinion gear would work?? Where do you guys with CD rom motors get your gear boxes?? Many thanks.
RE: gear box for Go-Brushless type cdrom motors
Most converted CD-ROM motors are used in direct drive applications without gearboxes. However, here are some threads on the topic.
[link=http://www.rcgroups.com/forums/showthread.php?t=347125]CDROM's and Gearboxes[/link]
[link=http://www.rcgroups.com/forums/showthread.php?t=282219]CD RAMP_UP SYSTEM (Awesome Power)[/link]
[link=http://www.rcgroups.com/forums/showthread.php?t=304873]Idea - cdrom gearbox[/link]
- Jeff
- Jeff
