Different motor for parkzone j3-cub BL
GA
Does anybody know what motor you could put in a Parkzone J-3 cub brushless that would have the same or greater power than the stock one?The stock one bends prop shaft easily and won`t come apart very good to work on.maybe an E-flite 400,but which one? a prop recommendation would be great as well...thx...jason
RE: Different motor for parkzone j3-cub BL
good luck on this one......i had the same problem. my prop shaft got bent and i could not figure out how to take the assembley apart to fix it. i took two pairs of pliars and got VERY lucky on the first try of bending it back. the shaft is an inexpensive part, if you can figure out how to replace it. hope somebody here on the forum can help! rob
GA
I have actually gone on ebay and found a 3mm prop saver from Heads Up RC to help with that.The set screws on the origianl motor are a joke.I`m a Jaguar tech by trade I have not found a good way to get those out except to drill them and put two more in another spot on the can....
