Electric motor prop saver
If a motor has a prop saver that is a part of the motor and the rim of the prop saver on the motor wares out what can you do. This makes it so the prop can't sit correctly. If you have this motor can you separate the top section from the base. I can pull the turning bell with the prop saver off the motor.This is the
C1822 Micro brushless Outrunner 2100kv (14g)
Thanks Ron
Thanks Ron
