motor advice plz :)
hi here's what I have
1.
axi 2208/34
12 amp esc
11.1v 830mah 3s1p 10c
2.
BM2410-08
18 amp esc
11.1 800mah 3s1p 20c
What is the best setup I should make with these 2
and is it comparable to a E-flight park 400 outrunner???
cause I want a dw foamies yak 38 inches and wondering if I will be ok
thank for your help
1.
axi 2208/34
12 amp esc
2.
BM2410-08
18 amp esc
thank for your help
I have found this about this motor
http://www.rcgroups.com/forums/showthread.php?t=472470
but im not so good with those number
TN
ORIGINAL: RickyD77
The Axi is an 8A max motor (though it can probably manage more - it did in my testing!), the BM is perhaps a 12A max motor (on only 6-cells? - since they say 84W max). Neither needs an 18A ESC, but it wouldn't hurt anything to use it.
Here are some data tables for the Axi
