Brushless motor
After doing some tests with my hovercraft wiht a friend he suggested that i may need more power for the motor its an AXI out runner 2826/12 but i am running lipos and i am not sure how much power i can put in the motor with out blowing it up so whats the biggest lipo i can put with this motor ?
With good air flow and the right ESC you should be able to run it at 800 to 900 watts peak on 9S to 12S LiPo. Watch the temperature, amps and watts. Stay under 140F, 25 amps and 900 watts. Continuous power should not exceed 600 watts.
What's the max rpm you are looking for?
