Go Back  RCU Forums > Electric Aircraft Universe > Brushed/Brushless motors, speed controls, gear drives
Reload this Page >
Battery and ESC compatable with a FP-R114H Receiver?
Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Old 12-01-2008, 09:32 PM
epiplayer3
Default Battery and ESC compatable with a FP-R114H Receiver?
I have a Futaba FP-R114H receiver i bought it used but in new condition I have a Pico stick f with a 280 motor my question is. What battery and speed control should I use and is a speed control compatable with this receiver. The manual says the receiver should have a 4.8v nicad should I stay with that voltage or go bigger or smaller Any help is appreciated im new to electric flight thanks
Old 12-02-2008, 11:59 AM
Dr Kiwi
Default RE: Battery and ESC compatable with a FP-R114H Receiver?
You won't need a separate Rx battery pack since the ESC you get will have a BEC (Battery eliminator circuit) which will supply ~5v power to your RX and servos. A 10A brushed ESC will be plenty since a 280 motor shouldn't draw more than 5A or so. Personally I'd get a Castle Creations Pixie 7P but there are cheaper ESC's out there. You should probably use no more than 7-cells or 2s Lipo for that motor and any pack big enough to supply 5-8A will be plenty (a 2s 15C 480 might be okay).
The ESC doesn't care what Rx you have.
If you intend to be in the game for the long haul (and don't already have a charger) I'd go with Lipo from the outset.
Old 12-02-2008, 01:06 PM
epiplayer3
Thanks doc much appreciated
