Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Pressing out shaft for changing ends
Old 12-16-2008, 07:11 PM
gemorse
Default Pressing out shaft for changing ends
I have been flying electrics for several years and have never had to swap the ends with the shaft. I recently purchased a Park Master 3D and the motor mount requires this to happen. It is a Himax motor. I have never had to do this and am a little leary. The supplied manual gives pretty specific instructions but still shakey about doing this. Anyone no any tips or tricks before I attempt to ruin it ??
Old 12-16-2008, 07:58 PM
Dr Kiwi
Default RE: Pressing out shaft for changing ends
Make sure you undo ALL set screws and remove any circlips. Separate the bell from the rest of the motor. Use a vise, not a heavy hammer. Use appropriate sizes from your socket set to support the bell as you press the shaft out. You'll need a drift (maybe a short length of a broken drill shaft) to press the last of the shaft out of the bell.
