GWS Gearbox, how to mount ?
TN
I need to mount a GWS gear box to a model that does not have a stick mount.
Anyone ever tried hot gluing the box to foam. Or, any thoughts on how to add a stick mount?[&:]
The model is my old and Sky Scooter.
Thanks ahead!
Thanks ahead!
RE: GWS Gearbox, how to mount ?
Eflite makes a outrunner stick mount part #EFLM1915
Your local hobby shop should have a couple hanging on the wall. They retail for about $4.95
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
TN
I have looked at this mount and am considering it as an alternative. It would require altering the front of the model and I really don't want to do that. I have been searching for a set screw type prop adapter that will fit a 1/8" shaft and let me use the GWS EP type props. Does anyone know of such. Or, I could use the APC slow flyer props but would need a quality prop adapter with a set screw.
I have tried the collet type adapters and they always spin loose. I tried roughing the shaft and using thread lock.
The model creates a lot of drag and usaully the prop spins off in flight. I could try slowing it down and flying it with a power system closer to what it was designed for but, who ever heard of such a thing! [sm=spinnyeyes.gif]
TN
For your adapter get this Graupner from hobby-Lobby: GR605331 Prop Shaft Adapter for 3.2mm (1/8") Motor
Shaft ..... $ 5.60
If your collet adapters come loose something is wrong... if they are the correct size for the shaft and you crank 'em down with a socket wrench, they'll never come loose.
Shaft ..... $ 5.60
My Feedback: (10)
melt a hole for the stick to go into with pc of wire. Spritz the hole and stick with some water, squirt a decent glob of Gorrilla glue or similar into the hole. Run some masking tape over the hole to contain a bit of the foaming action that will result and tape the stick in a way that gives you the alignment you want.
The gorrilla glue will hold the stick in place just fine.
TN
Dr Kiwi, Thanks for the adapter info. Will check it out tonight at the HL website. I still think the collet type was coming loose from all the drag created by the model. At the time I had an Axi 2212/26 & 8 cell AA Radio Shack w/ 9x6 SF. It didn't come loose every flight but often. Lost several adapters and props.
vicman, Thanks for your suggestion but I really dont want to alter the Scooter permanently. The stick would not be removable without some serious surgery.
I am thinking that since the new motor is a inrunner that I will mount it in a MP gearbox and use the set screw type adapter.
The gear could be hot glued to the foam like the original.
