Hacker to ESC connections
I'm just in the process of converting my first plane to electric after years of ic flying. I'm installing a Hacker A60-22S into a 2m Funtana (Exclusiv Modellbau) and need to connect the motor to the speed controller (Jeti Spin 99 Opto) ..... I'm completely thick when it comes to leccy wiring and the problem I have is that the Hacker has three cables coming off it - ALL BLACK and the ESC has a red, white and blue ...... how do I know which of the Hacker's black cables should connect to which of the speed controllers' cables? The destructions that come with the Hacker don't give any clues.
Your help, guys, is much appreciated!!!
GA
for a brushless system, it doesn't matter.... simply hook them up.. If the motor spins the wrong way (obviously be careful when you check) simply reverse any two wires......
