motor replacement comparison
I was wonder if anyone could help me I want to use a Typhoon motor 2W and I was wondering is another manufacture that has the same specs? I want the high RPM I was also wondering if Turnigy had a motor like the Typhoon. I am also wondering if I should get the Typhoon edf drive set with fan and ESC. Thats if anyone can help.
TN
This is quite a bit heavier (163g!) and comes in 3000Kv (some have suggested this is 3410Kv) and 2400Kv (the Typhoon (HET) 2W is 110g and 2660Kv):
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4206&Product_Name=KB28-47-13S_3000kv_Brushless_Motor_(FIN)
My Feedback: (35)
NV
Check this link and you will see a lot of motor data..
http://www.kcl2ay.zoomshare.com/files/Composite.htm
