Prop size?
FL
What is the proper method to determine proper size prop for a specific motor/ plane? I have an Astro wattmeter to use for this. I assume this would also be contingent on no. of cells in pack? I have not been getting much flight times and have ruined several packs by flying till cut-off.
TN
ORIGINAL: TedMo
Look at the max amps AND max watts the motor is rated for - never exceed either... and going no closer than about 80% of max is even better.
But don't believe every manufacturer's optimistic claims either (Rimfire for one, many (other?) Chinese makers too) - check your motor temperature after running your set-up static for 20-30 seconds - if the motor feels too hot, use a smaller prop!
