Reverse a Brushless???
I have a rear mounted brushless and i want to mount it on the front of another plane and i need the prop to spin the other way so it pulls the plane instead of pushing it!!!! any help is greatly appreciated
Hi, just swap around any 2 of the 3 wires that go from your motor to the ESC. Alternatively, you may be able to do this via your ESC`s programming mode.
LB
LB
TN
And make sure you mount the prop exactly as you would on the front of the plane [front convex faces of blades facing forward] - usually letters are stamped on the front of the blades... so those need to face forward.
