Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
calibration help!
Old 01-29-2009, 05:21 PM
typhoonspeeddemon
Default calibration help!
i just got a new jet, the f22 raptor and it tells me to calibrate the speed first with the ESC...so i plugged the battery into the jet after turning on the remote and putting the throttle all the way up like it says...when i plug the battery into the jet it beeps 3 times, then a steady beeping after that which it says counts how many batteries are in use or something and should emit a long beep to let me know when this process is done. problem is that it just keeps beeping steady with no long beep. i let it go for 3 minutes just to make sure but still nothing. please help!
Old 02-04-2009, 11:18 PM
AirmanBob
My Feedback: (14)
AirmanBob's Avatar
Default RE: calibration help!
When the looooong beep starts just lower the throttle to zero.
It might beep one more time to let you know its ready.
Hang on to the plane when you raise the throttle stick....
Bob
