Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Brushless Motor Help
Old 02-22-2009, 01:07 PM
coltons customs
Default Brushless Motor Help
Hello all
I dont know if this is possible or not but here is the scenario tring to run and park 370 that is installed into a tatoo gun of all things off of a tatoo gun power supply is there anyway to bypass the esc to operate the motor or how would a person "trick" the esc into being active as in the run cycle at all times as so when you press the machine pedal it would run the motor any ideas here
btw not my crazy idea just trying to help a friend
Old 02-23-2009, 07:17 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Default RE: Brushless Motor Help
http://www3.towerhobbies.com/cgi-bin...&I=LXVK79&P=ML
Take a look at this device from Astro Flight. You should be able to adapt it to a foot pedal control.
BTW, a brushless ESC is required to run the motor.
